Key Remote
Pozessed TS
Howzat Guys,
So recently I started having this issue where sometimes I can open the car with the remote on the key and sometimes I had to open the car manually, now she doesnt want to open with the remote at all.... :cry:
Any 1 had the similar issue? does it need to be programmed again?
Smartiesman
Programming the key is DIY but you need to find out why it is loosing config. Generally if the battery is not getting charged on the remote, this happens.
Have you tried your spare key?
msm
Pozessed 325i said:
Thanks guys, how do I remove the battery? Spare key does the same
Has the spare key been lying unused for a while? If yes, try using it for a few days and see what happens as the battery gets charged only while on the ignition.
However, rechargeable batteries eventually die and need replacing.
Pozessed TS
Aww so the previous owner was right, it does charge itself. Problem with the spare that I have is, it opens the car and puts the ignition onn and stuff but doesnt start it? so yip, guess it has been standing along time. Can I change the battery myself?
STupendous
i take it is an E46...
i'm waiting on some batteries...will let you know if it works....i should receive it 1st week July..
