I had this same problem, turned out to be the battery on the key. There is a youtube video with instructions on how to change the battery if you want to diy it. I would test it at an indy key specialist just to be sure though, as it could be a few other things as well, e.g. antenna amplifier or general module. Battery is the most likely culprit though.
Hope you get it sorted
Cheers
