Nastaliq said:I just checked the brochure.
Ventilated front and rear brake discs are standard from 316i all the way through the line. Brake discs here are the "rotors" and not brake pads.
The R7000 buys you "larger brake calipers in blue with "M" Badge"
According to real OEM and part numbers:
34106797606;
34106797602; and
34106797603;
The brake disc is referred to, which as 3 different part numbers are indicated are infact DIFFERENT, but no mention is made as afar as I can see of 3 different brake pads.
Its possible that I am a moron and don't understand how the components fit together and So I am telling you bullshit, but to me, better braking means better bigger actual brake pads that would need to fit into bigger cooler calipers.
Fitting stock pads into larger painted calipers do nothing.
A bit like buying XXXL condoms and you are sporting a lollipop stick.
This isn't a fight btw, I am also just trying to understand what the extra money actually gets you and whether in my opinion that's justifiable or value for money.
So if someone has a good handle on the parts and the "fit-together" of it all, please enlighten me.
I appreciate the insight, no worries bud, also trying to understand these options.
