Dean ///M
Limited Profile
I doubt that they would easily notice it cos of its location. If you can test for continuity and see whether it's broken further back or at the connector itself. In most cases the connector can be removed so cleanest would be to replace that one connector pin. No sure now is that oem sleeving is open if it is and you have to splice a wire on then run it in the same sleeving. Just tie up with Terry but I'm sure he is referring to the black wire.
