Introducing the << Woolie Wash Mitt >>
Pravin@crazydetailer
CrazyDetailer - Woolie Wash Mitt
R89.00
  • Holds loads of Sudsy Car Wash Water
  • Premium Grade Plush Synthetic Wool
  • Comfortable cuff to fit all sizes
  • Swirl Free Guarantee!
The woolie wash mitt is designed to hold the perfect amount of suds solution. You have to get the balance right, too much solution and you will end up tiring out your arms from the weight of the mitt, and too little means less lubrication or continuous dipping in your wash bucket. The woolie wash mitt hits that sweet spot which means you can squeeze to release the soapy solution as required, to get that perfect lubrication while gently washing your car.
With a massive 20cm x 26cm surface, you know you getting the best coverage and reach, which mean less work and effort. Work smarter not harder! Our new designed knitted cuff with fit securely around your wrist and maximize comfort.
The premium wool fibres ensure decent cleaning without the risk of swirl marks. Dirt is pulled into the nap of the fibres and AWAY from the paint work. This reduces the risk of damage to your paint work. The easy glide nature of the plush wool makes the task of washing that much more pleasurable.
http://www.crazydetailer.co.za/index.php?main_page=product_info&cPath=4&products_id=873
