hoosain said::bravo: thats an excellent time for a stock car
was this on friday night
Did you have the white m135? Run against you with my ti your car pulls strong was also having trouble with launching my car. Car had no traction was spinning a lot.Treschen said:my m135i is stock and was running pump fuel caltex. Need to work on my launchseems car was getting heat soaked after first 4 runs
ggrobler said:Did you have the white m135? Run against you with my ti your car pulls strong was also having trouble with launching my car. Car had no traction was spinning a lot.Treschen said:my m135i is stock and was running pump fuel caltex. Need to work on my launchseems car was getting heat soaked after first 4 runs
Was wondering did you also had issue with traction?
Treschen said:as it got past 7pm I found that wheels were spinning more weird ?
BillyBob said:Treschen said:as it got past 7pm I found that wheels were spinning more weird ?
Nothing weird about it --- As the track surface temperature drops, so does your traction.
Congrats on the 13.6 - what was your trap speed?
