Huge Quotation?
De@nO
Took my car in a few days ago to a very reputable shop in Randburg
Mechanical inspection was done. This is what came up:
- Rear trailing arm bushes (polyurethane)
- New front left lower control arm
- Caster bushes/ front lower control arm bushes
- Power steering pipe (Mine has started to sag and is rubbing on the sump guard)
- New discs,pads and sensors all round.
- New right side steering rack boot. mine is torn.
Total: R23 300.00 including Vat
Car is an '05 E46 320i 72000kms
They have already done a compression and leakage test and results were shap! Motor is fresh!
what u guys(n gals) think?
J
Jandre
Maybe run this past Gizmo as well, but I think it is way too much.
zaleonardz
That does sound a bit much man.
And if it is the shop in Randburg that I am thinking about, they are expensive out of principle.
What I would do in this case, source all the parts, prob for about 7 to 10k from what i can see, but thats a guess, and then either do that yourself, or pay an independant to do that.
All of the repairs mentioned above is are bolt and nut jobs, meaning that there are no real special skills needed to do them, so I guess, you will come out at about half that.
Bushes are about 4k.
Control Arm about 2k
Power steering pipe you can find at as scrap yard for about 300 to 500
Disk, pads all round is about 3k
Boot is cheap, just plenty labour.
This is about a day to two days to do, the bushes and the control arm you can have done at any alignment shop as well, most of them will do it, and you can buy the spares.
andrewbuch
Take it to Dave Robinson, 082 572 1049, 23 Milner road Randburg/Kensington B. As he is also in Randburg area.. See what prices he says.
But why not get Gizmo to do it, He can source the control arms, bushes and stuff for much cheaper
freerider
that is crazy! i bought poly bushes in dec in the housings for R136ea and had them installed for R600 incl alignment.
Discs cost me R900 a piece from bmw and pads R980 for the front set, i bougth the rears from midas for R360 and the discs are R400ea at midas (ATE) which is oem anyway.
De@nO
Thanks guys, Im going to pick my car up tomorrow, going to attempt to do most of the work myself.
Wish me luck!
Will probably be hassling for help! :)
Which poly bushes did you buy, if you dont mind me asking?
Hellas
Hey Dean, rather hang back with any work this week while you get some fresh quotes. R23k is a daylight ripoff!
De@nO
Are the BMW rear trailing arm bushes any good? Can get OEM one from dealership for 242.90 each. seems like quite a good price
Gizmo
Banned
OK so far I have got prices for:
Front pads R500.
Rear pads R400.
Brake sensors R150 each.
Front control arm bushes R1200 set.
Front left control arm R900.
I will get the rest of the prices tomorrow.
De@nO
Thanks Gizmo!!! :thumbsup:
Got oem RTAB's today.
Will get the rest of the stuff from you.
How much would 330i brake set be? I need 17" rims right?
Gizmo
Banned
Looking at around R700 per disc (new). Pads around R600 a set and 330i calipers around R1000 for the set. You do need a minimum wheel size of 17" to clear the 325mm disc and caliper. Other than that, its bolt-on and bleed, DONE!
@ri
@Gizmo (and i'm gonna jack the thread becuase I know De@nO is also thinking of doing this): Speaking of bleeding, have you done a CDV delete before? Would you recommend it?
Gizmo
Banned
I haven't done one before but its very easy to do. I would recommend it if you drive fast...
Gizmo
Banned
Ok Deano, I got your pads today. R450 for the front and R400 for the rears, I will pick up your discs tomorrow at R450 per disc, I will get new sensors @ R150 each at the same time.
andrewbuch
and he needs those things, his are finished and the way he drives he needs good brakes..
DE@NO remember bedding in brakes
