How to remove Bolt and crankshaft sprocket BMW e46?
jahsqf
Need some info on how to remove the bolt and crankshaft sprocket from my 2000 BMW 323i E46. Not sure if i need a special tool or if i only need to lock the flywheel with pin??? Please help.:roflol:
Gizmo
Banned
You need to lock the flywheel and use a very long breaker bar to remove the crankshaft bolt.
Solo Man
On my son's facelift 320d the one guy used a large screw driver to lock the ring gear and another guy used a torque wrench with extension to undo the big nut on the crank pulley. That was on a lift, btw.
kilotango
Solo Man said:
and another guy used a torque wrench with extension to undo the big nut on the crank pulley....
dude, please tell him to buy a breaker bar for that! i doubt that torque wrench will be correct after such abuse :thumbdo:
jahsqf
Thanks guys for the info. Got a lockpin and bar with pole lol.
