When you are about to hit the road on your holiday, make sure to get your car prepared firstly. Hitting the road for holiday is not as easy as turning the key and just leaving. You have to be conscious while driving, otherwise, the car will turn the worst possible time at you.
It is advisable to buy Japanese vehicles in South Africa for such trips. There is no way of predicting the occurrence of such events while you are motoring through the countryside however, you can keep along a lot of car maintenance parts before the time of leaving.
Motor Oil
Check on the motor oil by making it the easiest to-do on your list.
Gearbox and Different Fluids
Have the service of gearbox shifting be performed before leaving on holiday. Also, have a look at the grease points under your car since they are usually neglected.
Brake System
It is another important element to be looked over before leaving. First off, give a sight to obvious leaks and then pop the reservoir.
Motor Oil
Brake System
