How Good Is 2006 E90 320d
D
Dippies
it depends on the first owner ordering the car cause if he did not ask for spots BMW did not include the wire harness for it meaning that it would cost you about 15k to be inserted by BMW.
I know cause i asked. :fencelook: or that what bmw said
Silverbird_96kw
Eish hahaha ok, kwl thanx for the reply, the car has xenons so thats a + then
netercol
DNS said:
boet just be aware of a steering lock factory fault,kar just locks steering and refuses start,had dat problem on my previous 1:banghead:
yeah seems to be a common problem on e90's now.. seen two with this problem, very irritating..
Brendon.Myburgh
yah mine had the steering lock problem, they ended up replacing the entire steering column which suits me down to a tee. It was a 40k job inc labour still under M-Plan & had it replaced at JSN BMW in Bryanston but....
what a car, i love my vehicle.
You cannot go wrong
she will love you long time
Schumi
garywinter said:
Hi All
I went to test drive a E90 320d auto. I am very impressed with the way the car performs. The car has 102000km on the clock. Is there any problems on that specific year model that I should be concerned about?
Hi
I have a 2007 320d with 104 000kms. Bought it used, on 70 000kms and have never had a problem. Car was still under warranty, so I had BMW fix everything I was sceptical about. Just chaeck that there is enough life on the brake discs and that the clutch is not too low. There is also a recall on some due to loose fuel pipes that create a rattle noise... nothing serious.
Great car, enough power for everyday use and 16.1 km/l average consumption driving through Jhb traffic everyday. Get around 1000kms to a tank on Shell V-power diesel.
Shear driving pleasure !
DieselFan
I was quoted closer to 3k from bmw on my last E90 for front fog lights. I ended up just buying some aftermarket ones for R900 and then spliced them to the headlights.
chrisgvr
hi guys , im new to this forum . Just got my 2010 e90 320d sportpack, 76 mm piping , cat removed , this car is amazingly fast for a 20 L,it puts a smile on my face everytime i put the pedal now . Everything i read about this car is true .im so proud owning my first bmw , brilliant car .Diesel all the way .
