Hidden menu for F 30
Carmad
Hello fellow fanatics. I read a couple of times about a hidden menu in idrive to read coolant and or oil temperature. Does anyone know how to access this? Like I have got nothing to do while I drive around Gauteng, but I see oil temp on the analogue reader goes up a lot when traveling over 80 to 90 Khm and want to see actually what temp this is. I have a 2015 320i pre lci. Thank you
z_tayob123
Not on Idrive. It's on the instrument cluster.
Hold down odo reset button until the menu pops up. It takes a while
Doors must be closed and Bonnet
Ignition on or started
Menu will pop up. Press odo button once to go one down
You will have to go down to unlock
Press and hold on Unlock
Add the last 5 digits of your VIN
That's the code you have to enter. And you should be in
Sorry if I explained terribly. There a couple of nice vids on YouTube.
