gordanfreeman509
Hi guys, I recently took my 2005 e90 320d to my mechanic to clear the passenger airbag and seat belt error. We also picked up 9 Engine Related errors.
4 of them were for the Glow Plugs, in all 4 cylinders, that doesn't worry me too much as they likely actually do need replacing.
The following one doesn't worry me too much either as I recently disconnected the vacuum line from the EGR and started the car for whatever stupid reason. I reconnected it straightaway.
4501 Exhaust-gas Recirculation
The following codes do worry me however:
4C03 Message (Cruise Control/ACC, 0x194) defective, receiver DDE, transmitter
ACC / DSC / SZL / LWS
3F40 Rail pressure sensor offset test
And the grand finale:
44CC Charge-air pressure actuator
Also had an error related to the Intelligent Battery sensor, neglected to write down the specific code.
I will check later today to see if the Intelligent Battery Sensor is plugged in or not.
I will go back to my mechanic as soon as possible to see which of the cleared codes have come back again. The airbag and seatbelt lights are back on but I think that is to do with my car standing in the sun all day, maybe changing the resistance of the wires in the wiring housing under the seat.
My alternator pulley is making a hell of a noise as well, not sure if that could be having an effect on any of the errors. Wanting to replace it and the belt soon.
I can't tell if my car is underboosting or if it's just in my head since I saw the turbo actuator error but if feels decidedly different after I saw the scan results.
I know that I should just get my car booked in as soon as possible I am just posting this in case someone has had these specific errors before and maybe it was caused by something silly like a dirty MAP sensor and not the actual electronic actuator being buggered :thumbdo:
