Help needed: Boost issues
Smartiesman
Good day guys
I drive a E90 320d
I have been having an issue since December while on holiday :smashScreen::smashScreen::smashScreen:. The problem is that when I am in the higher gears and put my foot down, the rev needle jumps up a little and then returns similar to when your clutch would be slipping but the problem is the boost is not always there.
So I decided to take a look, not even sure what I was gonna look for under the hood but managed to find a silver pipe that comes from the turbo that looks to be loose if u pull on it.
Is that the boost pipe and is the symptoms similar to what I just described?
Any advice will be highly appreciated.
Smartiesman
ChefDJ@TheFanatics said:
Tighten the loose pipe and take it for a spin :dunno:
Lol.....I wish it was that simple. Looks to have some kinda seal or something. I am no mechanic....as me to fix your pc or server and I will know.
If it's a 320d (LCI) with the clip-off engine cover there is a known issue with the turbo linkage. It's quite an inexpensive repair. You buy the repair kit from BMW. You just need A LOT of patience.
Sent from my D5803 using Tapatalk
sash
Pre lci .
Smarties take a pic of the suspected part and the gurus will definitely have an answer.
