Help me help a friend- 2 problems on e36
gpgold
Hey guys!
I visited my friend last night and her 98 model e36 316i is giving two small issues:
1. her central locking locks/unlocks all doors except the right rear. The door needs to be locked/unlocked manually at the moment.
2. her outside temp display has suddenly stopped working. There is no longer a visible display. Could this be a light bulb inside the temp display?
Have checked all the fuses for both problems and they are fine.
Any suggestions? :fencelook:
racing snake
hi,
the door actuator might be faulty causing it not to function anymore.
the temp display might just be in need of a globe.
if she can bring the car over to me ill take a look and see what it needs so we can sort it out for her.
gpgold
racing snake said:
hi,
Thanks for the offer Racing Snake but she is in the Cape. Will look into the globe so long and see what can be done about the door afterwards.:thumbs:
Raybimmer
the actuator sits in a shyte position and is a 131tch to remove and replace .
The temp display may be moved out be sticking a finger under it above the open space below and moving the unit towards the gear lever .there are globes on the top side of the unit ( mine is full obc , I expect 316i to be similar , maybe not as many globes )
good luck .
Loom
good luck .
It's similar for the 316i. You can check if it's the bulb by shining a flash light at various angles at the display (make sure it is on, you can toggle it by pressing the "Temp" button) - if you can see the readout it's a faulty bulb.
Here's a pic of the back of the display of a 316i. The bulb for the temperature display is indicated by the arrow:
Loom
gpgold said:
Great stuff guys! :thumbs:Will see if I can sort out the temp display this weekend
Some auto spares shops might stock the bulbs. Please post back when you've got the door sorted.
pi328
Replaced all 5 bulbs in my cluster this weekend, so I have 3 spare/old bulbs. However, new ones are cheap: R15 plus VAT from the dealer.
