HELP: e36 rear left shock dome tear
VeNoM_Ct
Hey guys not sure if its called a shock dome...e36 rear left (passenger side) shock dome tear...see pics
Advice is required...
Some say best to weld it and re-inforce it while others say best to fit another dome (cut and replace)...
if I do replace the dome ( I found one but have not purchased it yet seems bit pricey) will the same thing not happen again?
I am sure it must have happened to someone here or have experience...
Please help me make a decision asap...
http://www.pelicanparts.com/BMW/tec...-Mounts/101-Projects-62-Rear-Shock-Mounts.htm
The 3 Series rear shock mounts (RSMs) are weak. These mounts hold the top of the rear shocks to the chassis. Repeated wear and tear on these mounts causes them to crack and break after many years of use. The worn-out shock mounts result in a clunking noise that emanates from the rear suspension while you’re driving. Left unchecked and unfixed, the broken mounts can inflict permanent damage on the chassis by tearing the sheet metal in the rear wheelwells.
Begin by opening the trunk and removing everything from it—including the carpeting. If you have an E36, you’ll also have to remove the rear speakers to gain access to the rear shock mount (see Photo 1). If you have a convertible, the rear shock mounts are located in the convertible top compartment behind the rear seat. Carefully pull back the molded carpeting in the trunk and remove whatever carpet fasteners hold the carpet down. Then remove the two retaining nuts that hold the rear shock mount to the chassis.
At this time, also disconnect the rear shock where it attaches to the rear trailing arm (see Project 61). Remove the entire assembly from the car disassemble it on your workbench (see Photo 3).
Around the time that the Z3 was designed, BMW realized that this rear shock mount design placed a lot of stress on the sheet metal surrounding the rear shock towers. As a result, BMW engineers have included a top-mounted support bracket that sandwiches the rear shock mount and distributes the load better (part number 51-71-8-413-359, about $15). BMW also redesigned the mount for the E46 3 Series cars, making sure the mount was backward compatible with the earlier 3 Series cars. This upgraded mount is used on the E46 M3 and E46 convertible cars, and is the mount to use if you swap out your rear shock mounts for replacement stock units (part number 33-52-6-754-096).
If you wish to go a step further in performance, install an aftermarket rear shock mount kit. I prefer the aluminum billet kit manufactured by Ground Control and available from PelicanParts.com for about $150. This kit replaces the rubber inner bushing with a polyurethane bushing that is much stiffer and far more secure than the stock mount. In addition, the aftermarket kit contains a beefy support plate that reinforces the sheet metal at its weak point. Installing the aftermarket kit is very similar to installing the stock mounts.
Reuse the plastic dust cover and the two concave washers from your old shock. Don’t reuse the rubber bumper, as these are typically near disintegration by the time most people replace the mounts. Use new self-locking nuts on top of the shock, and affix the rear shock mount to the chassis. Finally, use a new gasket to seal the base of the shock mount to the chassis. Reinstall the shock mount and replace the rubber boot on top if it was there when you removed the old mount. Reattach the shock at the bottom, reinstall any speakers or carpet removed, and you’re finished.
If you find your chassis sheet metal torn around the mounts, there is a BMW factory retrofit part that can be welded into place to repair the metal (part number 41-14-8-169-027 for the left side and 41-14-8-169-028 for the right side). Count on spending about $100 or so for a good welder to fit and weld these plates into the rear of your trunk.
calypso
Interesting first post.
But yes, check with the dealer, the replacement should be as cheap as chips. The labour on the other hand wont be.
this is why tower reinforcement is so important...
find a good panel beater to weld in a new tower
Dont forget to test your shocks too mines seized and caused that Yusuf (M3M5POWER) on the forum got replacement shock towers for me at about R400 ea
Doomsdaya
Common problem with E36's, while you at the panelbeater might as well get the front shock tower domes checked, also prone to damage...
Ralf*
[b]VeNoM_Ct said:
pid='855630' dateline='1388753674']
I presume you are from Cape Town ?
VeNoM_Ct
yes i am
R400 from where? OEM?
