Help car won’t start
rsgordini
Hi guys.
When car is cold no problem starting.
When warm it cranks but won’t start.
Following have been changed
Spark plugs
Fuel relay
Fuel pump
Fuel filter
Please help as car is currently stuck (waiting to cool down then will probably start)
Oh it’s an e36 m3 Coupé.. 188000km
Any help welcome
O82five91866o
Oh by the way I did search it and found this..
Crank position sensor
Cam position sensor
Beemerbro
hey hope you've sorted the problem- do let us know so we can learn.
but if not, you really should have a proper diagnostics done to pinpoint the problem. While the crank angle sensor can cause starting problems, it is not advisable to guess this sort of thing cos there are loads of components that can result in this problem right up to the DME itself, although unusual.It's cheaper to have a diagnosis done and fix/replace the correct part than fish around and incur unnecessary expenses
Peter@AEW
Either vanos related or position sensor related.
Crank sensor does not always show on diagnostics on early cars.
rbmwiv
Buy a veepeak or other elm327 diagnostics dongle. They are cheap under $20 and there’s tons of free apps that will let you read live data. The way I fix cars with intermittent problems is monitor the live data. You will be able to view all your sensors readings and then you will have a better chance of tracking it down. I would monitor crank and cam sensors readout with live data when it is acting up and if it’s a sensor issue you will most times get no output. Occasionally they will give crazy readouts.
Good luck
Beemerbro
I hear you that you've had a diagnostics twice with no error codes. But you don't say where or who did the diagnostics. I trust the BMW dealer systems more cos they are designed specifically for those cars. Other diagnostics software like INPA and others are very good but may have limitations. I don't know what software BMW dealers or specialist agents use. But i can tell you from experience that not all diagnostic software is reliable.
I would also speak to a technician specialising in BMW engines as he may have come across this sort of thing before so will know where to look.
In the meantime I would change the crank sensor, but I'm wondering if this might not be related to the fuel preparation and supply systems where the engine is "flooded" when hot and then needs time to clear:eek:mgwaiting:You would smell the petrol tho if this were the problem...just a thought:eek:mgwaiting:
evnmopwr
Issue sounds Sensor related
A guy with a 330CI came to me few weeks ago..
His car did the same... Wont start when hot.
He needed to cool off before it would start and drive..
Sometimes the car even cut out on him while he was driving...
Scanned and it showed Crank sensor.. Replaced that and he is driving fine last time i heard
Maybe just get her booked in at a BMW Mech. Drive it nice and warm before going to the mech. Then when you pull up at the workshop, the problem can mos be replicated. Then Mech can scan it and Most it will cost you then is R250. But scan it while the problem is there
good luck bud
SlimmJimm
On my polo it was a faulty temperature sensor...........overfuelling when hot i assume or something like that.
Changed it and it was fine, maybe check your temperature sensors
cato3
had same problem with a friend of mines e36 m coupe , did not want to start when hot and had the occasional misfire when on normal temperature , I got him a used ECU , problem solved , must actually get somebody to check out the old ECU to see what the problem was.
rsgordini
Car went to Sav speed... he diagnosed the problem but haven’t heard anything yet from the owner.. something about valves?
Will update as soon as I have more info
