H&R TRAK+ wheel spacers
kabal
outlaw335 said:
My oem's don't.I found this H&R 10mm pic on the net and it didn't make sense to me:
there is 99% chance that i would bet $100 that they 100% do :fencelook:
XMAX said:
I have seen Miss Sophie (Pre LCI E90 330d) use 15mm spacers in the front on 224/45/17 and 20mm spacers at the rear on 255/40/17. They looks awesome.
Im actually considering the same for my car. Or maybe ill go 15mm all round.
XMAX let me know when you ready :rollsmile:
andrewbuch said:
Where the pics I asked for? You are slacking Mr sales man :D
Sent from my HTC Wildfire S A510e using Tapatalk 2
lol ok ok will clean my car and take some pics this week :roflol:
Philip Foglar said:
Can one get OEM type wheels locks for use with spacers? :thumbs:
you can use your OEM wheel locks on DRA spacers they come in 20mm and up the locks i have fit over the nuts...
QikNish
Confirm ....DRA 20mm is actually 2x 10mm spacers to increase track width by 20mm?
i ask because i ordered "10mm spacers" elsewhere and got delivered 2x5mm. Had to return them.
Needs clearing up this... me thinks.
i quote giving each spacer thickness because people get confused :rollsmile: so 20mm DRA is 2x 20mm spacers and total track increase of 40mm...
H&R quote total track increase... I always confirm with the customer when they order :)
SP33DYV said:
@Moranor - Where's the peeekchas?
:fencelook:
XMAX
@Moranor... Definitely end of September.. Will pm you when ready. Will probably go with the DRA 15mm Spacers for front and rear.
Just hope that they dont rub. They didnt on miss sophie, but hope that they wouldnt on my car.
measure the gap then -5mm that should give the the correct thickness :)
S
SP33DYV
Still no pictures? I assume that you then never wash your car?:fencelook:
probably not as often as it should be washed :roflol: will make a plan with pics today...
here we go andrew :) 25mm spacers all round with oem 15" standard height...
then because it was dirty anyway:
andrewbuch
need more pics of the donuts :)
Looks good.. So I might just go for the H&r drop & then 15mm spacers at the back :) those fronts stick out too much for my taste :)
the tire on the front is a quite bulky 205 and rear is 195... also when you lower you will get about 1 deg extra camber up front so it will tuck the top of the tire in a bit :)
too much dust and blur in the other shots of donuts :(
andrewbuch
Cool, cause I am running 205's all round.
Think it will look good with 15mm Spacers and the drop.
Still saving for it though.
i would rather go 20mm because they DRA...
Front 205/60/15 (these are a very wide 205 though)
Rear 195/65/15
I have 195 at the back because i dont like them and i want to finish them... it also makes the car a little more tail happy :rollsmile:
I run 2.3bar in front and 2.6 rear... i was running 2.2bar in front but the dtc was freaking out because of the difference in diameter 2.3 seems to make it happy again :)
