trevor_e36m
And this is the final result, note the mismatching trim, I ordered the proper matching wood centre trim from an eBay seller in Estonia, let's just say big mistake! at the current rate, it will arrive sometime in the middle of the next ice age.
so I got impatient and sourced one from a breaker in PTA.
Impressions
- Sound quality is better than the professional radio (on-base stereo configuration). Did some research and this is due to the internal amp in the cic / ccc outputting more power.
- You get lci gongs, previously I had annoying chimes from the cluster, that I eventually coded out. I like the gongs for now.
- Make no mistake, this is no NBT, but it's still very smooth, menus are intuitive and there is no lag. Impressive for something from 2010
- The system has a large built-in HDD where you can store your music, I'm still enjoying some of the previous owner's music collection, thank you previous owner
-Transforms the interior, now you feel like you're driving a luxury german car
In a nutshell, well worth it !!
Things to note
- Navigation is vin locked, so its greyed out. You have two options to remedy this.
1. Get an emulator, it's a box that plugs into the factory harness and tricks the CIC unit into thinking its in the original car
2. Embark on The tricky task of modifying the CIC vin and messing with fsc codes.
I will be embarking on number 2 offcourse, have downloaded fsc tools and cic patcher v2, busy going through the various guides.Will post my success or lack thereof here.
Impressions
Things to note
