Gauteng: Balancing & Alignment Day @ Speedway
Arbee
BMWFanatics Balancing & Alignment Day @ Speedway
From Speedway needs help thread, the BMWFanatics events organizers have taken a step to help Ralf aka Mr Speedway promote his business by arranging a small get together at Speedway Motorsport.
On this day, Ralf and his team will be at our beck and call for the following services:
Balancing
Alignment
Minor exhaust work
If you require larger scale work carried out on your vehicle, you may speak to Ralf and his team to make a booking.
Date: 17 May 2014
Time: 11h00 - 14h00
Venue: Speedway Motorsport
R21 past the OR Tambo, take Cargo off-ramp(Voortrekker rd), keep to the far left, after the traffic lights stay in the far left and take the "slip-way" road onto Albatros/Pomona road, follow until it meets up with Pretoria rd at a 45 deg angle, turn right into Pretoria road, and the Detroit Complex starts with an Engen Garage, Speedway is in the complex, and is the last shop on the corner of Pretoria and Plane rd,.
Location : KEMPTON PARK ..GPS Co-Ords -26° 6' 44.20", +28° 13' 44.54"
A number system will be used as a first come first server basis.
Balancing - Normal price R40, Fanatics price R30
Alignment - Normal price R180, Fanatics price R150
Mid-Cat de cat R150 with straight pipe, R350 with resonator
Limited stock of Demon chrome exhaust tips, from R350
Look forward to seeing you guys there in support of one of our advertisers!
BMWFanatics Events
Tris
I will be there, was gonna call to make a booking for this saturday anyway:rollsmile:
mo335
Was so excited, I couldn't wait for Saturday! :rollsmile:
Thanks Ralf! :ty:
Balancing and Alignment done! :thumbs:
JodyD
Ill be in Durban will only go through on Sunday
Ralf book me down for brakes upgrade then :thumbs:
Ralf*
Thanks Ralf! :ty:
sunday ??
we aern't open on a Sunday....sorry !
Arbee
Lets get a list running:
1. Tris - Please add what you will be doing?
2. Arbee - Will pop by for a bit
3.
4.
5.
6.
7.
8.
9.
10.
List will also help Ralf determine if all staff or just a few are required.
vicky1275
3. Vicky- Alignment and balancing
4.
5.
6.
7.
8.
9.
10.
Flash-Gordon
4. Flash-Gordon - Alignment and balancing
5.
6.
7.
8.
9.
10.
Thunder
5. Thunder - Will try pop in for a bit
6.
7.
8.
9.
10.
Silverbird_96kw
6. ChefDj - Alignment and balancing + suspension check up (bushes etc)
7. Silverbird_96kw - Alignment and balancing + suspension check up (bushes etc)
8.
9.
10.
Ralf*
Thunder said:
Anybody going that might need some stickers?
what was the price on the "Paul Walker" stickers again ?
PS....we aren't set up for you Two-Wheel-Thunder-Machine.
:rollsmile:
Ralf*
Chavoos said:
Do u have the small 63mm resonators to replace mid cats on the N54 as previously discussed?
not sure, if we keep 63mm resonator's in stock, I have left a message with the floor manager to check...and will get back to you tomorrow
the normal that we stock is 57mm, but we can order for you and have in the shop for Saterday (Cowley)
Ralf*
Chavoos said:
Thanks . What length and what's the price?
If the price and size is right. I will fit it
will need to find out if we stock 63mm, if not will need to order from Cowley, and then I can give you the price
message addedendum sent to my floormanager
