G8x M2-M3-M4 - KW HAS Kit (Height Adjustable Springs)
FiRi@Rennzport
KW’s sleeve kit for the G87 M2 / G80 M3 / G82 RWD and X-Drive allows a large range of height adjustment while retaining the factory electronic damping control. The factory spring perches are removed from the front dampers, and KW’s own threaded height-adjustable perches are installed. The kit includes progressive rate lowering springs for each corner of the car, height adjustable spring perches for the front and rear, strengthened and shortened bump stops and KW shock sleeves to protect the OE BMW dampers. The KW H.A.S. kit is EDC compatible and fits both RWD and AWD variants!
Lowering Range:
G80 Front Lowering 0.4-1.0″
G80 Rear Lowering 0.2-0.8″
G82 Front Lowering 0.6-1.2″
G82 Rear Lowering 0.2-0.8″
KW H.A.S.: Height Adjustable Spring Systems
Fits:
2021+ BMW M3 (G80) Sedan; RWD, AWD incl. M3 Competition
2021+ BMW M4 (G82) Coupe; RWD, AWD incl. M4 Competition
2023+ BMW M2 (G87) Coupe, 2WD
PRICE : R20,900
••• RENNZPORT •••
Firi 065-950-6027
Zee 083-401-2299
Nationwide Courier Available
