so guys - i was told my ecu is dead because my car was not fueling:blab:
it has a new crank angle sensor and a new cam angle sensor but does not start. Yesterday i had some free time and decided to check her out. Here's what i found:
- fuel pump does not turn on when i turn the ignition.
- fed 12v to pump - it went on momentarily
- with the pump on the injectors sprayed in sequence(ECU surely cant be faulty then?)
- The pump dies after a minute or so when in the tank but runs constantly when out of the tank (not submerged)
Symptoms of a faulty fuel pump? what else?
