front light showing faulty then normal
basheervd1
Remember i posted a thread of my car that burned and up to now had no luck in what caused it i think i might be onto something a while before the car burned my right head light showed a fault and i thought it was a bulb but then it was fine again then my rear lights showed a fault my right tail light pin was burned and no earth on license plate lights after fixing that it showed again right head light error after a couple of minutes it goes away then on again i thought the problem wouldve been solved because as per my mechanic he replaced the front loom but i discovered he only joint it from where it burned so i need advise cause i starting to get really freaked out that it might burn again so i just disconnected the battery so could it be that theres a earth problem on my loom
sash
wierd experience, sorry i have no info to help, hope the other guys will chip in soon
basheervd1
this is very weird and i dont like this weird error esecialy when it comes to wiring issues it seems im sitting with a unusual problem thats irriating me
I think you need to get this car to a good auto electrician not worth taking a chance on this...
