Front bushes !
Stiffler_PE
How such an innocent thread could degrade into a dirty version of garden and home :)
Allow me to bring things back on track... not ginna be easy after the thought of shaved twin bushes were brought up... so to say :drool:
OK... I can now give full report back on the poly bushes.
The quality of the bushes upon visual inspection is ok, was kinda concerned at first but upon clser inspection relaised it was all good.
There are a few tiny pin holes and a bit of extra polyurethane here and there ( we used to call it flashing on the plastic model planes ?? )
But how pretty it looks has nothing to do with how it performs... agreed ?!
I am all for DIY.. but this is not a 1 man job lol. If it wasnt for my heavy i would not have finished.
I used sunlight liquid to lube the shaft ( i am opening myself to a whole host of chirps arent I !! )
The first bush went on pretty easy, got it on far enough with my boet lying under the beemer and using 1 x leg as 1 x press :)
Got one hole to locate and off we went.
Second bush was a leeeetle tighter.. once pushed on it would slowly slip off ( and onto my forehead :censored::censored: )
BUT they are on... decided to buy new bolts from stealer as well for the bushes.
Sent car for wheel alignment next morning ( not required by the look of the results )
HANDLING:
Immediate impressions... WOW... now this could also be because i have gone from rattling good fit to new poly bushes.
But... WOW.
Car feels amasing and SOOO direct. cornering feels flatter and sharper.
I would have to say that if you want a silky smooth Beemer ride.. this may not be for you. I can feel the texture of the road through the steering wheel :drool::drool:
And im pretty sure i can detect fresh white lines on the road too :mmm:
All in all... never mind the look of the bushes... they peform !!
I dont know what aftermarker rubber bushes would feel like... anyone tried so we can compare ?
I think i am going to just replace every bush front and back through George.. at those prices it is so cost effective !
Cheers !
Stiffler_PE
Hahahahahahaha... Zaleonardz. I would prefer you dont stop. Nothing like a good laugh to iron out a bit of stress :thumbsup:
Donovan.. i do have pics. On the cell phone... will make a plan ( need to do the photobucket thing i assume )
1 downside to the poly bushes.... i am driving harder, faster and for longer :pimp: so the fuel bill is going up :slap:
StK
Sorry for the thread hijack but as we on front bushes I thought people may be interested.
Here's some pics of the bushes and control arms I fitted onto my E36.
I used Powerflex bushes and E30 lemforder control arms.
Difference between the E36 and E30 control arms
Hacking the old bush out of the lollypop
New Powerflex bush in Lollypop
Fitting them back onto the car
I also put on Powerflex anti-roll bar bushes
The difference is phenomenal.The polly bushes work well with the E30 Elbows :thumbsup:
The E30 Lemforder elbows are a direct replacement on the E36 and are a good upgrade and also cheaper than E36 Lemforder elbows.It gives a more feel of the steering :thumbsup:
Stiffler_PE
Cheers for the pics... but take note that i drive an e46 and there is a difference between e36 and e46 LCAB's :thumbsup:
Big difference though hey !! Poly rocks lol :pimp:
StK
Yeh I know but as the thread title just said front bushes.....pretty much anyone with any model is going to read this so they can see waht can be done for the E36 too :thumbsup:
Be good to see pics of what you have done to your E46 :thumbsup:
Stiffler_PE
Good Point StK... never thought to make the subject more specific, THANKS :clap:
Will organise pics as soon as i get a gap... Need to sign up with photobucket so i can host he pics.
StK
Raybimmer said:
STK
Hi Costs ? Were Power flex bushes sourced locally ? ( Not : bushes sauced , Leonard !! )
'Fraid not,All parts were from Euro Car parts LINK which is local for me however bit far from you guys....Am sure you can get polly bushes produced locally but powerflex have a reputation for been the best....If you are desperate for powerflex bushes then I can get you the costs of them and price for shipping too.Also checkout the powerflex website LINK
Edit: I found 2 powerflex distributors in SA :thumbsup:
D&S SHOCKS
122 NORTH RAND ROAD, RAVENSWOOD, BOKSBURG, GAUTENG,
Telephone: 0027 ( 0 ) 87 807 7642
Email: [email protected]
TURBO NETWORK
64B RALLY CENTRE, LAUDA RD, KILLARNEY GARDENS, CAPE TOWN, WESTERN CAPE, 7441,
Telephone: +27 82 443 1887
Website: www.turbonet.co.za
Check how much they'll do them for and I'll check if I can get them any cheaper from here :thumbsup:
would polyurethane not cause excess wear on other parts?
i have to do my bushes now and the mech that does my car says the worn bush may have made the end oval which will make the other bushings go fast as well as damage the steering components...
i just had my steering rack and power steering sorted so dont want to do it any time soon...has anyone else had this problem?
these repairs are eating my modding budget...
Dwayne_Russell
So my bushes on my E46 330 are also done, bad knock over bumps and a little movement when steering.
you guys recommend the poly parts over the rubber then from a stiffer ride/handling and durability side??:thinking:
Raybimmer
Poly or Rubber ?
IMHO rubber should do the job and help to get the ride back to standard i.e. as new . Poly bushes may make steering feel more direct , but feeling every bump in the road will soon be a pain in the butt and I would expect some rattles to surface .
zaleonardz
but whats wrong with a little rattle on the surface when using rubber on Poly, and does Poly have a sister ? Cause you know you have to do them both at the same time...
ive read it 3 times and now have 3 different meanings to what you said...
are you saying that if you have poly bushes you need to replace all your bushes with poly? rattles i can live with but replacing expensive components because the poly bushes are to hard im not so keen on...or are you saying you want to F%$# Poly and her sister? :p
