Focusing headlights
LPM320
Hi Guys
Need to focus my headlights on my e36 328i. The headlights are badly out of focus. Any advice on how to focus them?
Thanks.....
Nastaliq
If you pop the bonnet you'll see two white little gear looking things right behind your headlights. Use a #2 phillips screwdriver and adjust accordingly.
Theres two on each side. The one farthest to the outside of the car adjusts horizontally, and the one that is center between the bulbs adjusts vertically.
More info here: http://www.bmwe36blog.com/e36manual.zip
And i think its only decent if you up my reputation please. :wave:
Nastaliq
Click on my name in the top of this post, then a page with profile details will open up, then next to reputation, you will see "Rate", click it and then you can give me reputation points.
thanks dude.
Nic_s
lol, trading Info for Rep points.
Also have some WD-40 near by if it's a bit sticky. :thumb:
Blain
Hi Nastaliq
Do you perhaps know how to adjust the headlights on an e46 facelift with xenon's ?
Promise to give you a rep point:)
Nastaliq
Isnt that the way it goes?
Blain said:
Hi Nastaliq
For the E46, the thing that gets adjusted looks like small thumb rolls with a torq screw receiver in the middle, but sometimes they can look like white plastic screws that you have to turn with an allen key or whatever its called(dont know what size though) so look for that.
I think the e46 xenon facelift has auto level adjusters, just like the E90s,they also have a sensor, which sometimes gets "pongy" and cant calculate how to "level" out. Do you lights go up and down when you switch the car on with the headlamp turn knob in the on position?
Blain
Blain said:
Hi Nastaliq
Yes my lights do go up and down when i start the car.
Nastaliq
then you have the autoleveling feature.
Please PM me your email address, and I will email you a pic of what the knob looks like.
dont forget my Rep point :)
Blain
kabal said:
the autoleveling, and the alignment are 2 different things when it comes to bi-xenon. you still have to align them correctly
here is the proper alignment guide - http://m3forum.net/m3forum/showthread.php?t=176238&page=2
Thanks Kabal just printed it out gonna try it later.
You've been PM'd
Hehehe wats with u and Rep points:hammerhead:
Sankekur
Uhhmm, the headlights going up and down when you start the car is not auto-levelling headlights, the lights just do that so that they both are set at the same high according to the setting on the LCM panel.
