Hi Xcede & X-flow will be running some specials in the run-up to the festive period. Specials will start on the 1st October & run up until the 1st December, where after they will revert back to the normal list price.
Xcede N54 Stage 2 Himalaya port flash + X-flow custom catless downipes are normally R 5 500 + R 6 500 making it R 12 000.
For the special it will be R 7 500
Xcede N55 stage 2 bench flash + X-flow custom catless downipes are normally R 7 500 + R 5 500 making it R 13 000.
For the special it will be R 8 500.
We will also add a carbon clean which retails at R 3 500 for the special price of R 2 500 if done in conjunction with the above specials. So for the N54 it will be R 10 000 for the flash, DP & Carbon clean. For the N55 it will be R 11 000.
Add a drop it filter & oil cooler valve for R 2 000 for both specials.
