Now spray in the windscreen when I tug the stalk, no sound of a motor sunning either; could it be as simple as a fuse (which I can sort), or do I need to take it in?
I had a similar problem with my 2012 F30. Took the pump motor out and iirc there was a lot of gunk in the bottle/reservoir. Was a while back so have forgotten the detail but just needed a good clean and it worked and has been working since.
I also had a similar problem but in my case I could hear the pump but there was no water coming out the jets. Removed the inner fender lining on driver side and removed the washer bottle. There are 2 filters where the pump sits and it was clogged with gunk. Cleaned and fitted everything back and it worked fine.
