F30 campaing
Gbmw
so far all good on mine. I take her every 2000km. dunno if that too much or too little.
F30Sline
Iceman007 said:
Took my F30 to check alignment and they had to remove the rubber drain grommets
they were so clogged up. I think somewhere a F30 had a fish tank. Believe me make sure you get yours done
http://www.realoem.com/bmw/showparts.do?model=3D35&mospid=54108&btnr=64_1881&hg=64&fg=35&hl=23
The above is what they remove. its Item No 4 on all F models
Hi
Refererring to your post, where did you go check the alignment on the F30? At the dealer or regular wheel and tyre shop? My cars on 1500 km now. Will probably take it in to check the alignment at 5000 km. Just not sure where. Thanks in advance for any help.
Iceman007
Well I was at the dealer but for some reason they could not get the steering straight. They then sent it somewhere else for alignment and it was perfect. So it must have been another tire place. Some dealers do not have an alignment machine and they outsource it usually. Just find a good tire dealer with one of the latest alignment machines and you should be good to go.
:thumbs:
