F30 335i fuel pump module/VVT sensor query
Yuben
Senior Moderator
Guys, my friend had a flat battery on his 2013 335i. After getting the battery charged, he was experiencing loss of power under acceleration. He had diagnostics run, and it cam up with faulty fuel pump module and faulty accelerator VVT sensor. Can't comment on the diagnostics, but would low voltage cause this type of malfunction?
Jive_E46
IMO I dont think the battery would cause those specific error codes to come up, maybe after the charge those faults were kind of exposed in a way. The 2013 N55 suffered from Valvetronic issues(servo motor/ eccentric camshaft/oil nozzle sprayer). VVT is VANOS, so if theres VANOS codes then it could well be an eletrical issue, although I'm betting that it was Valvetronic 3 codes.
The Fuel pump can also pack up after a long period of time.
Try disconnecting the battery and check if codes persist.
Sent from my SM-G975F using Tapatalk
KPM3_30
Moderator
Also just check how badly the battery dropped charge. I know the newer BMW's don't like low voltage and you end up with errors when the battery gets too low.
Yuben
Senior Moderator
Thanks Kev, we hoping a new battery will solve the problems, the battery size is 658...
AshG108
Its a 335i, he will need a 90amp battery....but the latest OEM ones are 92amp.
Then (as per the whatsapp group), he must get it coded to adjust the battery charge rate.
Then clear all codes and run the car again...
Danny2
yeah make sure that the battery is coded once replaced and clear the codes.
If you want i can assist if he wants me to have a look.
Send me a PM
