technical F30 335i boost leak and maf sensor
Wayno@135
Good day all,
Have a 335i however it has a drivetrain warning. When plugged in at a service centre to read the codes, saw there was a maf sensor issue as well as a boost leak. I have cleaned the maf sensor and tried the unplug it test but no difference and drive train error still comes back, I'm assuming it's because of the boost leak and/or I need a new maf sensor. Is there any recommendations for someone who can assist with testing and fixing the boost leak in the gauteng region?
khumalbs
Good day all,
Run a boost pressure test (smoke test) on the car. On my F30 335i - my pressure leak was coming from a damaged crank shaft seal leak.
