S1NGH 911 said:
I've had my exhaust done with the dual split (335i) style, but added a 300mm silencer in the middle
Ok
Did you do the complete exhaust. I assume you did.
Why did you add the 300mm silencer in the middle? Was there a drone. What diameter is the plumbing?
I just want to delete that massive rear silencer and replace with straight pipe. I want to keep the look original so ill keep both tail pieces on the left. Ive seen on the BMW performance exhaust they replace comllete exhaust with no resonator and only a silincer in the middle and no back silincer.
There is a resonator on the standard exhaust so I reacon just a split with 2 pipes in its place to the rear would work? Or is there a catch?
