F10M5 100 to 200kph times
Kolbe
Hi, what are the 100 to 200kph experiences on an F10M5 at Gauteng altitude? I did two runs yesterday at 1400m altitude, 23 degrees outside temp., with my F10M5 which has a Bootmod Stage 2, 91 octane tune. Results were 6.9 and 7.1 seconds. Am wondering what the effect of our Gauteng altitude has on the 100 to 200kph times - would love to hear from fellow forum members. Thanks.
Sherwin@xcede
Same engine but in 2.3 tonne X6M this is my verified run:
At sea-level you will run faster.
Ralf*
Kolbe said:
..... Am wondering what the effect of our Gauteng altitude has on the 100 to 200kph times - ...
I wasn't aware that we had any roads designed for 200km/h in Gauteng ??
yush1
Heres the Mark Jone test of the F10 M5 CP at altitude. Shouldn't be much difference for a non CP.
Kolbe
Wow, that's impressive - must be a very strong engine. Care to share the mods and dyno figures?
Kolbe
Thanks - that's very helpful. I see the F90M5 test by Mark Jones at altitude has very similar results to my F10M5 with BM3 Stage 2 - both on 80 - 120kph and 100 - 100kph.
Kolbe
Thanks - that's very helpful. I see the F90M5 test by Mark Jones at altitude has very similar results to my F10M5 with BM3 Stage 2 - both on 80 - 120kph and 100 - 200kph times.
Ralf*
R5000 Bail ....not fine....BAIL !!
which means arrested, taken to the "tjokkie"/"slammer" before getting bail from the magistrate
Court date and sentencing/fine still to follow
what for ?
EMePkVBWkAA2G6w
Kolbe
what for ?
EMePkVBWkAA2G6w
Do you read posts? - GEROTEK!
QikNish
x6m makes more power than the F10 m5 though right? And 8 speed auto vs 7 speed dct of the m5?
ajm
That's impressive. I note from the Mark Jones test of the F10 M5 that he starts the 100-200 run in 3rd gear. Do you do the same or do you start the run in 2nd gear?
Kolbe
I start the run in 3rd gear at around 70km/h and need to change to 4th at the end of the run before I hit 200km/h.
ajm
Noted, thanks
