Sohail said:
sash said:
technically it will fit, but you will have higher chances of rubbing,
what are your current tyre sizes?
Currently got 17 inch with 225 and 255
if you mean 225/45/17 then 245/40/19 is 7.1% bigger, on my 5 series, the recommended tyre is 245/35/19. I wouldn't use it, but if other guys have been using 7.1% bigger circumference tyres with no issues, its upto you.
your rears are 255/40/17 so 275/35/19 is 6.5% bigger. Keep in mind that the bigger the percentage smaller or bigger will affect the accuracy of your speedo.
