Exhaust for E36
topclub
What is the best exhaust diameter for my E36 325i ? 57mm? My car is a M50 I believe the branch is good and should leave it stock just replace the down pipe and right through to the back, what u guys suggest
if you doing a full system then you should do branches as well... if it was just a decat then you can keep the stock items...
I can offer you:
Viper branch R 1685
Dyno tested Full Viper exhaust system including branch R 7640 (JHB and DBN only)
Peejay
Events Organiser
I can offer you:
Viper branch R 1685
How many kW gain?
topclub
I was thinking of leaving standard branch and doing the rest of exhaust so what size do u guys do for my car (recommend)
I was thinking of leaving standard branch and doing the rest of exhaust so what size do u guys do for my car (recommend).
Sorry double post
you looking at a 10-20% gain on a full Viper system but every engine is different so there is some variation in results...
let me see if i can get a dyno sheet problem is they filed under car reg so finding the right car takes time :(
Abel wont give out his recipe but duel 50-54mm works well for that size engine...
the bends and welds are also critical its not just about pipe size...
plenty shops out there are willing to slap a crush bent system together cheap with over penetrated welds that can knock or rattle so be careful who you choose...
if you just after noise a Decat (not sure if your car has cats) and a free flow back box are your safest cheapest bet
