engine missfire, white smoke, fan running full speed, fuel smell
sash330ci
Hi guys, needs some help urgently here. My 335i N54, in the mornings the car takes long to start and when it does start, the car idles very very rough, clouds of white smoke comes out the exhaust with a strong fuel smell, the radiator fan comes on at full speed yet the car is ice cold! If I clear the faults the car runs fine until its gets parked off over night for a long period of time. Help please.
And check engine light comes on aswell
sash330ci
ShaunB said:
Usually when the fan comes on at full speed when you start the car it is waterpump.
Here is the list of codes its giving
2DEC
2CFB
2D09
2C2E
29D2
29D1
29D0
29CC
29F1
Acheron
2DEC
2CFB
2D09
2C2E
29D2
29D1
29D0
29CC
29F1
Sounds like you've got injector issues to me, likely a one or more leaking injectors hence the misfire codes/white smoke after leaving it overnight.
sash330ci
Sorry forgot to mention, I did downpipes 3 weeks ago, car started smoking from then, but that smoke had oil smell in it.
boost3d
Acheron said:
2DEC
2CFB
2D09
2C2E
29D2
29D1
29D0
29CC
29F1
+1 Sounds like an injector issue to me
Is the car still under plan?
ShaunB
Sounds like the Cats on the original DP's were blocked thus only started smoking after the new ones.
Woodies
Wow lots of possibilities unfortunately, but injectors would be a good start. Some of those errors are also boost leaks. Check if the charge pipe hasn't cracked? Was software done for the DP's?
What's the mileage on? Smoke after catless DP's is common as the old DP's might have been masking the problem. Another list of possible causes for that..................
hoosain
Sounds like a injector issue
Access fuel in the combustion chamber in the will cause difficult starting in the morning and smoking untill that access fuel is burnt up
