E9x D1S recommendations
Which Xenon Bulb would you choose
  • Phillips White Vision
    Votes: 2 66.7%
  • Osram Xenarc Cbi
    Votes: 1 33.3%
  • Total voters
    3
boost3d
I am in the process of doing a ZKW 3" clear lense upgrade on my headlights, looking to couple this with new d1s bulbs, does anyone have any experience with the following bulbs on their cars
OSRAM Xenarc Cool Blue Intense D1S or Phillips D1S XENON WHITE VISION
ps, there is nothing wrong with my current xenon bulbs, i would just like to maximise the light output of the clear lense upgrade and after 7yrs of use, i think the bulbs could do with a refresh
akash
I cant speak for the xenon type bulb
But on the halogen side i would rate the Phillips over the Osram hands down if that helps.
wikked
Banned
From my limited research, the Osram CBI's seem to be the the best you can buy at the moment
https://www.theretrofitsource.com/bulbs/oem/d1s-osram-xenarc-66144-66140-cbi.html
https://www.hidplanet.com/forums/fo...ntense-quot-must-see=&highlight=cool+blue
corp said:
What is this clear lense upgrade?
https://www.theretrofitsource.com/blog/headlight-tech-clear-lenses/
NtandoN
Haven't used phillips but osram is great quality. My e90 still has osram bulbs from 7 years ago.
Riaad
Events Organiser
Mine just went off... After 8 years... Replaced with Philips... Output of light is better imo...6000k... So light is alil whiter compared to the osrams (5500k ifrc)
wikked
Banned
Don't confuse light temperature with light output. 6000k may look whiter than 5500k, but that is just the colour of the light and probably has no bearing on how much light is being output
Riaad
Events Organiser
yeah, reason i made that comment was the bulbs have the same wattage (35w) and these ones look brighter ...then again, they dont have 8 years of use on them just yet:hammerhead:
i think i have a photo, will try and find it later on:thumbs:
boost3d
So these are the details i have gathered
Stock light 4300k
Osram 5500k
Phillips 4800k
based on my research 4800k is actually the best type of light as it most mimics daylight....the higher the K, the light output diminishes as the light becomes more blue/purplish
With regards to the Clear Lense...if you have a look at your current headlight, you will notice that the lense is actually "cloudy" , i think this is for the way light is diffused . The clear lense just allows more light to pass through.
https://www.theretrofitsource.com/a...HID+Equipped)&preselect=&preselect_restrict=1
