E92 M3 with new twin turbo from X5M
Pravesh
sc00by_gp said:
Must shunt!
does it slot straight in, or is there need for cutting, squeezing ect?:excited:
George Smooth said:
Pravesh said:
Wow how do you service...what about the heat soak....i still think supercharger is the way to go...but unbelievable workmanship.
Heat soak and supercharger come hand in hand. You cannot even compare turbos vs superchargers when it comes to heat soak. In this case using the new twin turbo motors keeps the cold side on the outside which according to the initial reports neither the X5M nor the X6M or the 550i suffer from bad heat soak. I think you might have missed the part that this is the X5M engine and not a custom conversion.
thanks for the info George did not know it was the new m engine. What is you take on the 550i do you think it will be super strong when remapped.Is the engine totally different from the M engine...regards Pravesh
