E90 Vacuum Pump
Hi Fellow Fanatics
And yet again a cry for help, the vacuum pump on my 08 320i started leaking oil, leaving me with the occasional white smoke inside the cabin. I'm going to repair the vacuum pump by replacing the O Rings gasket seals. If there's a fellow fanatic that did the same DIY can you please assist me with the specs of the O Rings that you used, Specifically on the inside of the pump.
Kindest Regards
