E90 runflats
grim101
Hey
Just sold my e36 after I could not get it from stop chirping.
Bought myself a e90 320i.
120 000km
2007
Getting it on Monday.
The vehicle has runflats. What does this tyres cost? Is there a way to put on normal tyres and adding a sparewheel or space saving sparewheel into the boot? Is it normal for the tyres to feel hard?
Cant wait for my car
70007
It would help if you give the tyre size...sport pack (17"), M-sport (18"), normal exclusive which could be 16" or 17" 's
But yes, you can go non-runflat with a big improvement on ride, but you'll have to get some kind of back-up like tyre weld (which won't help in a blow-out, or the space saver which in turn takes up some boot space)
Sent from my iPad using Tapatalk HD
Lizzard
Cheapest tyre i could get on a 18" runflat was R3500 each. That is the okish tyre, if you go name brands then start cutting
Ralf*
1) Not all RFT's are so expensive, you can get cheaper options such as PACE, whilst not * (star) rated, which is a requirement for MP , it is still an RFT, and in some cases 1/2 the price of the Bridgestone RFT's, and only slightly more expensive than "normal" Non-RFT" tyres
2) Normal tyres can easily be fitted, but you loose the safety factor
3) Yup....will take up space (tyre weld will only work on small holes like a nail)
4) RFT's have sidewalls that are extra strong and very rigid, essentially allowing you to run on the sidewalls strength alone, when the tyre has a puncture, but that also means way way less ability to absorb the roads uneven shocks and bumps, thus very hard ride quality
grim101
Thanks for the advice. Its a normal executive 320i.
Is it a good buy? Any problems I should look out for?
firaz
That's not a question to ask here.
Just search the forum and you'll find this has been discussed many a time. Guess it's a bit too late anyways.
Sent from my HTC One mini 2 using Tapatalk
grim101
I did some reading before buying but maybe missed something. Will make sure next time to search before asking a question on my thread!
vjx
I just changed my 17" rear 255/40/17 to Michelin non-run flat.
Softer ride shows immediately. But i felt less stable driving on uneven road. Very weird.
Donovan2412
To what pressure are your tires pumped?
vjx
Around 2.5 bar. Weird.
ET was here
weaker or softer sidewalls, means that the tire will have more lateral ability to move, which leads to sensation of being less stable
vjx
Is it really true that E90 designed with runflat? People sit at back row complaining dizzy. :biglol:
