E90 LCI 320d battery replacement (Durban)
///M Individual
Hi guys,
A friend of mine with a E90 LCI 320d needs to replace his battery (Size 668 AGM)
BMW want R4500 after discount.
Battery Centre Chatsworth is around the same price for a Raylite AGM 80AH.
Are these the going prices at the moment?
Also I have read some older threads of having to register the new battery - is this something that a dealer/workshop does or can it be DIY.
///M Individual said:
Hi guys,
That's about the going price. If he has an original battery ask him to check if that sight glass is yellow. That's only when he should change it. If it's black then I suggest he puts it to charge over night for a few nights and it will then show green. A friend of mine had that issue. It's been 5 or 6 years now. He's still using that battery after the few nights of trickle charge.
In terms of the battery registration. I'd say grab a buddy with an inpa cable. I'm sure there's a few guys here around your area that will be able to assist. It's really quite easy so nothing to it. 5mins job
Hope this helps you out
Cheers
Sent from my ELE-L29 using Tapatalk
///M Individual
Hi guys,
Cheers
Thank you very much bud - very informative and helps alot.
First step will check the sight glass - it is possible that the battery just ran low as he has two cars that he alternates between.
Diesel
Hi
Just checked my receipt and it was R2100 in 2017. Prices have gone up alot. I bought mine from bmw umhlanga as they were cheaper than battery centre umhlanga.
My mechanic works for bmw and he did the install and registration. Let me know if you want his contact number. He stays at the beginning of verulam.
///M Individual
Diesel said:
Hi
Thanks for the reply bud - yes the price has increased drastically.
Yes please pm me his details.
preggyn78
Please also check the distill water. The wife’s F30 alerted on the I Drive and disconnected some electronics. Took a look and the cells were dry. Bought distill water and till today it’s perfect.
///M Individual
Will do Preggy thank you!
Kyle
Thought these were sealed batteries?
Riaad
Events Organiser
Hi guys,
Give Durban Brake and clutch (the jacobs branch) a call...i fitted a varta battery recently, think it was around 1.8k iirc :thumbs:
Iceman007
Its a load of bull this sealed battery's. Once the warranty is gone pull the sticker and oppen the caps and check the level. Even better advice buy some battery accid and top it up to cover the plates. Dont be surprised if you use a liter in the process. Then a good charge and the battery should be fine.
I have recovered a few batteries like this
Hi guys,
Hi Bud
I can help with the battery registration, you can DIY if you have the tool.
PM me
///M Individual
Hi guys,
My bud had the battery tested and it was on its way out.
Managed to get a Varta from Atlas Battery for R3100.
Thanks very much for all the help. Much appreciated.
AshD
Hi guys,
I have a 2011 320D E90. Need assistance to code/register new battery on the vehicle. I currently have an 80A AGM battery. I will be fitting an 100A SMF battery. Please PM. Thanks in advance
///Herbie
Just an update to this thread.
I am currently in need of a battery and got quoted by these places so far (Cape Town)
Battery Centre Montague Gardens: R6275.55 includes VAT and return of the scrap battery. Raylite brand 36month warranty
Bosch Service Centre Claremont: R2960 incl. VAT. Bosch S4 668P
BMW SMG Century City: R3989.82 incl. VAT. R402.50 discount if you supply your old battery. Excluding registration/coding of battery. (Part Number 61217587068)
  • Like
Reactions: tjc
