So another FYI
Front passenger door actuator failed, tried replacing the fuse with a 20 amp fuse, didn't help, main problem is in any case the door actuator that causes the fuses to blow.
Door unlocks by using the handle inside but not with keyfob or dash unlock button.
Again I took it to BMW Midrand and the quote is below.
Found quite a few DIY posts on this issue but decided to let them handle it in case I accidentally break a window or anything haha :smashScreen:
Replace actuator - http://www.e90post.com/forums/showthread.php?t=477507
