Hi guys can you assist me. My e90 330i auto has developed a shudder from the rear. This only shudders at low revs when you accelerate then dies out as the revs pick up. It does not shudder at speed either. I have checked the gearbox oil seems fine. I have checked the prop bearing seems fine. I have checked the prop shaft rubbers that seems fine. I have seen there seems to be a sign of slightly worn control arm rubbers /stabalizer links at the rear. Could this cause the shudder at low revs when accelerating or do I check other arears on the rear end.
