P1000 said:You should have bought a 330 then...
Not much you can do to make any real gains, apart from fitting a supercharger (read $$$).
Onyx said:P1000 said:You should have bought a 330 then...
+1
P1000 said:The BMW is WAAAY better than a golf that can only squeeze 85kW out of a 2l... I think you should be very happy with the performance of the BMW then...Only way to get real gains is to spend money. Cone filters and that type of mods only work on golofs...
Edwinz said:P1000 said:The BMW is WAAAY better than a golf that can only squeeze 85kW out of a 2l... I think you should be very happy with the performance of the BMW then...Only way to get real gains is to spend money. Cone filters and that type of mods only work on golofs...
Hey look i never said i am gonna do cheap mods.
I wanna spend cash.
you cannot drive a bmw and go cheap on it. Classy car, Classy mods.
328ii said:You can try play with lower tire profile and differential ratios
to get better acceleration but lose a bit of top end.
8?>
Jakkals323i said:I agree with leaving it as is..
Look it's not a fast car out of the block but when cruising there is nothing wrong with it. It has power higher up in the rev range and that's ok.
Anyways i doubt you looking for a robot to robot racer but as a high speed cruiser it's a great car..![]()
Also something that i did try, i know i wasn't gonna get far is try a private strip against a polo GTI. not the new one but a '08 standard at the time i tried it. take the revs up to about 2.5k rpm and then let go of the clutch. you pull that little polo but once you both go to 2nd gear you gonna start having a problem.... lol lol.. but in it's own, a lovely car cause i have one too..![]()
From what i heard is that people say you can flash the ECU to 325i software as it is the same engine and only the manifold that's different and you will gain a few extra kw. but do you really wanna go that route ?
I thought about it and decided if i want something faster i will have to buy it.
Hope it helps a little and congrats on the car![]()
