E90 323i losing coolant
DRCraig
Good day ladies & gents
Apologies if this has been discussed before; can't seem to find a similar thread.
My dad drives a 2006 323i E90 Auto. It loses coolant rapidly. Under acceleration or when revving, there is water coming out of the exhaust- must top up frequently.
There are no oil and water mixing in the coolant resevoir, no misfire and no overheating.
The car has a fairly new waterpump, thermostat, radiator and oil cooler.
Please advice.
Regards
DarrylvanNiekerk
Check under the oil cap if there is any milky residue.
Does the car smoke a bit as well?
It could be head gasket but it could also be a water leak too as there are a lot of points that weaken with heat cycles.
DRCraig
No milky residue under oil cap and no smoking. Also thought head gasket; no symptoms other than coolant disappearing.
DarrylvanNiekerk
Were the O-Rings on all connecting pipes changed at the same time as water pump, thermostat, oil cooler and radiator?
It can't hurt draining the cooling system, pulling all the O-Rings and replacing them as they deteriorate and deform allowing for a bad seal.
If it is leaking that badly you should be able to find the leak with a pressure test.
There is a horribly difficult to reach water gasket at the back of the head which can leak and rust its retaining bolts.
