DarrylvanNiekerk
I have recently finished rebuilding my e90 320i engine and run it in, done about 3500km - car runs great.
I need to update my thread on this as I learned a lot and hit so many snags along the way - my first engine rebuild.
Resleaved, new rings, new bearings, new coil packs and sparks, sonically cleaned injectors, new exhaust valve guides and valve stem seals - 13 bar compression test.
I have a suspicion someone in the past played with the software but the car doesn't throw codes - my frame of reference is that the 6500 rev limiter has been removed.
I can either have the latest software replaced or add an aftermarket chip to confirm the car is running properly and at its best - probably both around the same price. The car does have a full branch CAT delete and free flow exhaust.
I have asked around and am considering taking the car to Dastek to have a Unichip done where they will tune the car on the dyno. Are there any other reputable suggestions that are Joburg based?
I know most would comment not to waste time or money on a NA 320i but after spending a lot of time and money on it I want to make sure it is performing optimally.
Thank you in advance.
