E90 320i taking water
JerryP
Hi guys,
I have noticed in last 2 weeks that my 320 is taking water every 10days.
The coolant light is coming on. I have not noticed any water leaks
How can I trace the fault. Please advise
Regards,
Jerry
kilotango
if you're not seeing any traces of coolant anywhere around the engine bay, then you could take the car in to get the cooling system pressure tested to see if theres a possible leak. im not too familiar with e90 common leaking places.. but im sure someone will chime in soon.
also, confirm if you're using coolant and water mix, or straight water when you're refilling?
Danny2
one of the guys in our office had a similar issue where by his E90 335 was using water.. Upon further investigation we found that the expansion bottle was leaking
