e87 to 3uz
Captain_Stealth
mk_liamsaidthat said:
hi guys i would like to know can i convert a e87 to a 3uz motor but still retaining orginal bmw gearbox?
If it’s a manual box then yes not sure about the autos
Camnefdt
you can keep any combination gearbox with any combination engine as long as you're willing to put the money and time into conversion kits and adapter plates
Captain_Stealth
i cannot find any adapter plates
Got a well know person. He does quality stuff
Oom Fana
(083) 752-1655
KPM3_30
Moderator
@"mk_liamsaidthat" One post is all you need, no need for multiple threads on the same topic. If network connection is bad, take a break and refresh your browser - do not hit post repeatedly.
mk_liamsaidthat
Oom Fana
(083) 752-1655
thank you
Captain_Stealth
Before going a head know what you getting into
My mate Mark does conversions this is what you pay for a properly done reliable conversion
3uz vvt motor R 18 000.00 , cambelt R 1 250.00 , cambelt tensioner R 950.00 ,cambelt idler kit R 1 450.00 ,water pump R 1 600.00 ,thermostat R 500.00 ,spark plugs R 500.00 ,oil filter R 300.00 ,oil - 15w40 shell helix R 400.00 , auxillary belt 6pk2275 R 450.00 ,aux belt idler bearing R 100.00 ,auxillary belt tensioner bearing R 100.00 ,power steering pump kit R 900.00 ,alternator refurbish kit R 600.00 ,starter motor refurbish kit R 800.00 ,new starter motor cable 25mm R 300.00 ,new spitronics harness - full sequential R 2 000.00 ,throttle body 1uz vvt R 1 500.00 , strip / clean / paint / plating / assemble R 2 800.00 , TOTAL R 34 500.00.00 , 3uz vvt 5 speed gearbox fully prepped R 6 500.00 , hayden oil cooler R 1 350.00 , type4 toyota atf ( 3 tins ) R 1 200.00 , new spitronics harness R 1 680.00 , TOTAL R 10 730.00 , mercury 2 ecu for engine control R 4 600.00 , mercury 2 tcu for gearbox control R 3 400.00 , fuse box R 350.00 ,4 control relays and sockets - bosch R 900.00 ,TOTAL R 9 250.00 , universal brackets R 380.00 ,heavy duty engine mounting rubbbers R 1 100.00 ,TOTAL R 1 480.00 , AIRCON SYSTEM REGASS TOTAL R 400.00 , supply and fit external pump R 950.00 ,fuel filter regulator - 3 bar R 350.00 ,10mm plastic filter R 100.00 ,hoses and clamps R 300.00 TOTAL R 1 700.00 GRAND TOTAL R 58 060.00 exhaust system R 4 200.00 ,spitronics installation and wiring R 3 500.00 ,anti freeze R 300.00 ,hose clamps - air filter R 250.00 ,air filter - K and N R 650.00 ,propshaft bolts R 200.00 ,usb socket and wiring R 400.00 ,extra power cable and lengthen starter cable R 350.00 , consumables ( sleeving / lugs / wire / heatshrink / cable ties etc ) R 1 600.00 ,petrol R 400.00 ,16 inch radiator fan with mounting kit R 900.00 ,TOTAL R 12 750.00
so then add what gerhard bought , hydraulic hoses and fittings for gearbox R 1000.00 , silicone radiator and air filter hoses and clamps R 3000.00 , new propshaft R 3600.00 , powdercoating gearbox / engine mounting brackets R 500.00 , secondhand engine crossmember R 1 000.00 , TOTAL R 9 100.00
so now the total comes to R58060-00 + R12750-00 + R8100-00 = TOTAL R78910-00
now this is excluding removing the old motor and gearbox , and fitting the 3uz with gearbox and doing mountings as gerhard did this with his guys himself , now add in say another R8000-00 for labour
GRAND TOTAL R87910-00
A lot of ppl get caught in this story of 50k conversions. Be careful
