E83 Oil Filter Housing Gasket Replacement
Ozzycat
I need to replace the oil filter housing gasket on a 2.0 diesel so bought it and the heat exchanger gasket. I've searched youtube etc for a procedure guide but very little has come up for the M47 engine I wanted to know if the heat exchanger is only attached to the oil filter housing and if it can be removed as one unit. Saw a video on youtube of a guy removing it as one piece on a 120d with same engine however a manual I saw on the web seems to say it two pieces and you need to remove the glow plug module as well to get at the heat exchanger. There's not a lot of room to work and it looks like I need to move quite a lot of parts around to make space to do the job.
Anyone done this job and have any pointers to make it as easy as possible?
Thanks for any advice forthcoming.
