brukutu
Guetzer said:great job man! ive been dreaming of building a carputer for a year now lol. where did u get the lilliput screen and how much did u pay for it?
Mp3car.com
220 us.
Great service....
calypso said:Awesome project, cant wait to see it done and in action.
Depending of what install you planning to do,Guetzer said:
applehero said:Man that sucks... Just like Murphy messing you around - Build and test everything, and when it comes to install it doesn't work.
I'm not very knowledgeable on electronics, but...
Perhaps with the extra amps the battery needs to output, makes the ecu freak out (I assume it did this while the car was on). So would try supply the necessary current, overshoot that, then under compensate it.
Also, from what I've seen from the OBC hidden menu, is that the voltage while the engine is running is around 14 Volts. Don't know if this will affect things...
A further thing to check is that no wires on your made up board are loose. Perhaps that is the intermittent current issue... :dunno:
Tefo said::thinking: :mmm: ill have to read this again
alphajoe said:Hi Brukutu, thanks for your answer! If you succeed doing that, it'll be a great job! :clap:
On my side, I am still struggling with getting an appropriate audio-cable (2.5mm -> 3.5 mm
stereo (gold contacts), pin-jacks at 90 degrees, length 1.0/1.5m) for my mio v735...
I am looking forward to seeing your pictures of the connection of the CID to the radio.
Cheers, aj
Everything done only waiting for CID to mount screen and still need to solve power issuesapplehero said::wave: Any more progress?
zaleonardz said:Howdy,
I just read your explination about the 15A pulses, it sounds plausable.
I think we do a 12v to 12v DC powersupply. I dont know if you know anything about powersupplies, but in essensce, this device monitors a DC signal, converts it to AC electronically, passes it though a transformer, rectifies it back to DC.
The added advantage of this is that if you have unstable power input, that you can stabalize the output electronicly. a fluctuation on the input is detected, and the conversion frequancy to AC is then increased, as visa versa.
I know we do 24 to 24 not sure about 12v though, will check it out.
Our quint range of powersupplies also have a "boost function", meaning a 10A supply can give double its current rating for a short time period, such as motors starting up.. but actually, our power supplies can deliver double its designed current rating indefinatly.
I will check on the morrow if we have a 12 to 12, and that should sort out your stablility issues
