thireshan said:Hi guys
Can someone advise which make of bearings are advisable to be put on these cars and whom in cape town i can contact to get this done.its a preventative measure for a car im purchasing.
Thanks in advance
Like TUTU says:922-ZN said:thireshan said:Hi guys
Thanks in advance
BE Bearings with OEM rod bolts(new of course), finish and kla
Peter@AEW said:Like TUTU says:
BE Bearings if your budget allows as they have addressed some of the known issues.
Second option is Agents.
If you go the BE route get ARP rod bolts if not get OE bolts.
individj said:Peter would you then run the car with these bearings with confidence for hundreds of thousands of km's?Or do another change after 100 000 or so? Also would you change to a thinner oil?
Peter@AEW said:individj said:Peter would you then run the car with these bearings with confidence for hundreds of thousands of km's?Or do another change after 100 000 or so? Also would you change to a thinner oil?
Would run it to 200 000 Kms with those bearings.
Provided the engine is hot before being driven hard and oil changes happen every 10000Kms.
I might then use a 0W40 with Ceratec for added performance.
I am not advocating that others do the same merely my opinion if I were to drive one.
BeemerFanatic said:From learning on this forum, Buying a second hand M car definitely needs new bearings no matter what's the mileage because you don't know how the car was treated, warmed up, oil services etc. also once done you need to take care of the car, warm up the engine, do regular oil changes
Also do a gearbox check / service. I just found out brakes on an M is like 30k
Wow makes me wonder if I will ever be able to afford any M car.
mgwaiting:
All inthireshan said:Approximate pricings on the BE bearings and oem bearings and all the other needed stuff as mentioned above?
Peter@AEW said:All inthireshan said:Approximate pricings on the BE bearings and oem bearings and all the other needed stuff as mentioned above?
Budget R30K for OE and R40k for BE.
individj said:Peter@AEW said:individj said:Peter would you then run the car with these bearings with confidence for hundreds of thousands of km's?Or do another change after 100 000 or so? Also would you change to a thinner oil?
Ok..have they not changed the specs of the bearings for better clearance? Sorry i am not as technically minded as you guys but i am trying to get an idea. I read somewhere that measured OE bearings have changed over time & there is more clearance.
individj said:i see Tune Tech are of the opinion that the stock bearings don't have enough clearance as in its too wide.
