E60 3Button 434Mhz Key Programming?????
Kinnear
[/b]Good Morning BMW fanatics i have a Question for you guys....
1.If your key is not opening the car but still starts the car and you are unable to get the key programmed will it be able to use a diffrent car key from a diffrent car then program it so it will open your car. i know it wont start the car but will it open it.......
2.On a e60 model with the3button key with steel pin still fixed forward it this the right way to get it programmed
get in teh car and shut the door. put the key in the ignition and turn it to position 1 (right before start) only leave it for like 1 second then turn the key back and take in out. press and hold the unlock button and press the lock button 3 times. At this time the vehicle will lock then unlock if done correctly. when the first one has locked and unlocked the vehicle take the second key press and hold the unlock button and press the lock button 3 times. (no need to put it in the ignition) this again should lock and unlock the doors. If you have more keys they all have to be done at this time also. If this doesn't work your screwed. LOL nah if this doesn't work try holding the lock button and pressing the unlock button 3 times. then if neither works you have bigger issues.:bangdesk::bangdesk:
